Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Export 3D Design to DXF
9 REPLIES 9
Message 1 of 10
KLathwell
899 Views, 9 Replies
KLathwell
Hi Guys
I am really struggling.
I have various models that I want to send  for Laser cutting. My guy can use dwg, dxt or steps files but I have problems when I try to export to any of these formats.
I want to send my 3d Design to him in 2d so that he can just download to his program and start cutting
Despite reviewing many you tube video's I cannot find one that describes the process in a logical way.
I have tried a number of methods but all seem to keep the original design or do not export accurately with parts missing or not correctly dimensioned
Can someone suggest a tutorial or You Tube video which properly explains the process.
I have attached one export example in the files below, it's a complete mess.
Hi Guys
9 REPLIES 9
Message 2 of 10
TrippyLighting
in reply to: KLathwell
TrippyLighting
Please attach your model in .f3d format to the next post.
Message 3 of 10
KLathwell
in reply to: TrippyLighting
KLathwell
Hi Peter
File now attached. I hope you can help me
Hi Peter
Message 4 of 10
HughesTooling
HughesTooling
@KLathwell wrote:
Hi Guys
If you want 2d you'll need to create 2d drawings. Just downloading as a DXF does not magically create 2d drawings, your DXF opens in Rhino fine as a 3d model as expected.
You need to create 2d drawings from your model. See help.
Mark
Mark Hughes
Owner, Hughes Tooling
@KLathwell wrote:
Hi Guys
Mark
Mark Hughes
Message 5 of 10
TrippyLighting
TrippyLighting
You should check out the "Arrange"  feature.
Once arranged, you can project the outline of your boards into a new sketch and export that sketch as a dxf.
Message 6 of 10
KLathwell
in reply to: HughesTooling
KLathwell
Hi Peter
Thanks again, so if I understand, there is no magic way to export a 3d model directly for laser cutting so I need to make 2d drawings for all parts of my model
Hi Peter
Message 7 of 10
jhackney1972
jhackney1972
If you have a Fusion 360 Subscription License you can use the Arrange command as @TrippyLighting has already suggested.  I created a Screencast to illustrate what he suggested.
John Hackney, Retired
Message 8 of 10
TrippyLighting
TrippyLighting
@KLathwell wrote:
Hi Peter
No, you don't understand that correctly!
I simply thought that's what you wanted.
So you already exported a 3D model in an as-assembled state into a DXF file as @HughesTooling was able to show.
Obviously, that model cannot be laser cur in an assembled state. At least not on any Laser cutter I am aware of.
That necessitates another action. The question you need you to ask yourself then what information a Laser cutter needs to do what you want. So before continuing to propose workflows, you need to answer the question of what "your guy" exactly needs.
A Laser cutter cuts material out of flat stock. That means it needs a path to follow in a flat plane. The workflow I described outputs that pattern in a 2D DXF.
If "your guy" states that he can also use a STEP file, then the process is similar, but you don't need to create a DXF  sketch. Exporting the arranged geometry as a STEP file might be OK.
It is clear that you lack some basics, so I would recommend you communicate with "your guy" and ask him what exactly he would expect to see in the STEP file. Then provide feedback here and we can move forward without having to waste more time with assumptions 😉
@KLathwell wrote:
Hi Peter
Message 9 of 10
KLathwell
KLathwell
Hi Peter
Thanks for your support, I now have various work arounds which work for me.
If I use the manufacturing tab method I can export a detailed STP file which is completely accurate when I open in a another program so I am happy with this method
Hi Peter
Message 10 of 10
KLathwell
in reply to: jhackney1972
KLathwell
Hi John.
Thanks for your support in this matter. I now have a couple of ways to export.
Hi John.
