Exploded views with rigid groups
jesse3M545
jesse3M545
Does anyone know if it's possible for exploded views to treat rigid groups as a single component?  I routinely import PCBAs into Fusion in which the board and parts are separate components, so I make them a rigid group.  But then when I insert the PCBA into an assembly and make an exploded view I have hundreds of PCB components flying everywhere.  Thanks!
johnsonshiue
Hi Jesse,
I could be wrong but I don't think Animation environment honors the Rigid Group designation. To preserve the subassembly as a while, you may use "Auto Explode: One Level" command.
Many thanks!
Software Test Engineer
rosie_lucas1
Hello @jesse3M545
Just checking in—did the response shared by @johnsonshiue help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
