Explode Polyline DXF for export/import to 3rd party software
Currently trying to export the Sketch9 in the attached to a DXF with 'exploded' polylines. The 3rd party software it's being imported to is MotorSolve by Infolytica and they are able to reliably produce 'exploded' polylines using AutoCAD and Solidworks. I typically use IronCAD for the heavy modeling work, but their DXF export (which 'explodes' by default) does not align using the y-axis because it exports from one view drawing only.
The Fusion exported DXF registers the orientation correctly, but MotorSolve cannot recognize some or all of the polylines.
Thank you!
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can try to use this Fusion 360 App - DXF Spline to Polyline (link here) to see if that will convert your DXF to Polylines. I do not believe that Fusion exports Polylines by default to DXF, which is probably why you are seeing these errors. Let me know if that worked or not!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi @James.Youmatz,
Unfortunately the app did not change anything, the DXF still contains unrecognized types of polylines.
IronCAD exports the DXF in all AutoCAD versions in a format that can be read by MotorSolve, however it is impossible in IronCAD to align the DXF with the y-axis as required by MotorSolve.
I automatically assumed that Autodesk would be exporting DXFs in the same format across all software, or that it would at least be possible to export in the same format!
All I know for sure is that if AutoCAD is used to export the DXF it must be 'exploded' and NOT polylines. Also there are no splines in the sketch that I am generating which accounts for no difference in the resulting DXF.
Thank you for the suggestion though!
johnemartin
I have a similar issue - trying to export Fusion dxf into Nikon VMM. If I export a simple rectangle, the Nikon interprets it as a polyline not a set of interconnected lines - Fusion engineer told me that Fusion is sketch-based, not vector-based so the sketch is always exported as a polyline.
I really wish Fusion would allow me to simply explode my sketch into lines - like AutoCAD, LibreCAD, DraftSight, etc. IT shouldn't be that hard.
