Expanding a line circular?
Would like to get a circle to extrude centered on these six lines or spokes.  Need to create and manipulate cylinders radiating out from the side of this cylinder...
Screen Shot 2018-11-01 at 11.30.20 AM.pngthanks!
JDMather
1. Assuming the Origin is at the center - create a circle on one of the planes going through the origin and then Extrude.
Pattern the Extruded cylinder.
2. Another option would be to sketch a Rectangle and Revolve the rectangle.  Then Pattern the revolve cylinder.
File>Export and then zip and Attach your *.f3d file here if you can't figure it out.
(You might not need to zip if the forum has been fixed.)
etfrench
If the cylinders are not identical, then create a sketch on each line by starting with the 'Plane on Path' command.
ETFrench
g-andresen
here is one way to realize it.
günther
This community is just amazing!! Thanks so much.
mavigogun
Be sure to Accept the solution- otherwise, folks will think there is still help needed here, spend time where it is no longer needed.
