Exit sketch without saving.
r_goulter
r_goulter
Is it possible to exit a sketch without saving it?
Currently am having to Finish Sketch then delete the sketch.
etfrench
Clicking on Finish Sketch exits the edit sketch mode.  Why does your workflow need to delete a sketch without using it?
ETFrench
jeff_strater
no, there is no way to exit a sketch with out "saving" (really, meaning: commit all the changes to that sketch).  You can undo all the changes if you want, but a sketch is not a separate "saveable" entity.
Jeff Strater
Engineering Director
mango.freund
Hello, are you not aware that every action can be canceled with the arrow-back option? It often happens to me that I open a sketch and all of a sudden I realize that fusion has also memorized another level. pfeil <- is trendy. greetings mango
r_goulter
?Thanks, that works fine. I had been looking for a Cancel button.
