Exisiting Model as a Construction Line
cannonj222
cannonj222
Community Visitor
Community Visitor
Newbie here.
I have imported a model. I want to make a new part that fits the existing model, but that is not permanently attached or change the original model.
Is there a way to turn the original imported model into a complete "construction line"?
My idea is to see and work in relationship with the original model, but be able to turn it off leaving only my new part.
Thank you,
jhackney1972
One method is to save the imported model out to the Cloud, then create your new model and Derive the imported model into it.  You can use the derived model as reference and then remove it later.  Be sure and create your new model as an independent entity only using the derived model as reference.
John Hackney, Retired
cannonj222
Community Visitor
Community Visitor
John,
I previously imported and saved the original part to the cloud.
If I understand, I should start a new part (sketch). Then DERIVE the original model in and start working.
Do I start with a blank work surface or do I need to create a random object that I then adjust to the DERIVE?
Does the DERIVE need to be toggled on/off when I am done or does DERIVE automatically retreat to the background? Thinking 3D printing here.
jhackney1972
I am thinking you want to use reference geometry from the derived model to create your new component.  As I said, make sure the reference geometry is not directly linked to the derived component so you can Break the Link of the derived component and then remove it.  If you have not used a derived model before, do a very simple test so you can see what you can and cannot do.  After you finish some simple bodies, practice Breaking the Link and removing the derived component.
Edit: Once you have your derived  model in place, you can create sketches and features referencing it.  Everything you create will only use references to the derived component.
TheCADWhisperer
@cannonj222
One of the experts here will demonstrate multiple techniques using your actual data.
etfrench
Import the model into the new file. Create the new part. Remove (not Delete) the imported model.
ETFrench
