Error when combining bodies
salah918PSM4
Observer Observer
salah918PSM4
Observer
Observer
Hello !
I'm trying to design an iPad case with Fusion 360:
From there, I wanted to extend a little bit the bottom part of the case.
I used the project tool in sketch mode and extruded that extension as a new body:
Now I want to combine both bodies, but it always fail with this error:
vertex intersection found but stored pointer NULL
How can I combine the bodies ? Is there a better/easier way to achieve what I'm trying to do ?
I've attached the f3d file.
Any kind of help would be much appreciated, thank you !
jhackney1972
Please check my dimensions but I think it is correct.  You need to move the added Extrusion ahead of the fillets on that end.  Model is attached.
John Hackney, Retired
salah918PSM4
Observer
Observer
Perfect, thank you !
