Error using modeled thred
hato54
hato54
I like to 3Dprint a M8 thread and have to check "modeled" in the dialog.
M6, M14, M18 works!
Get error, but if I uncheck "modeled" it works.
Strange?
/Håkan
innovatenate
Autodesk Support
Autodesk Support
Is the hole going the entire way through the block or only partially? I'm trying to reproduce this issue on my side, but having some difficulties.
Does the same issue occur if you restart Fusion 360 or restart the computer?
Nathan Chandler
Principal Specialist
hato54
I tested both  the entire way and  through the block and partially, same error.
Now I closed Fusion 360 and restarted the computer, now it works!
Thank You Nathan!
/Håkan
