Error saving a 2D drawing
rozzautodesk
rozzautodesk
When I trying to save a 2D drawing created from one or more components I receive the following error.
Warning: Fusion Drawing failed to generate a small thumbnail.
Error: Save of document 82NW - Back Porch Drawing - Roof Framing v0 failed
Aside from this error, I have nothing else to really go on.  Please ask any questions that you need to, and I will be happy to provide the information as needed.
kris_berg
Hi @rozzautodesk,
Sorry to hear you are having these issues.  In order for me to start diagnosing it, can you send me, kris.berg@autodesk.com your logs?  To retrieve your logs go to the help (?) menu and select the "Diagnostic Log Files" command.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
kris_berg
Hi @rozzautodesk,
I have been investigating your logs.  I am going to need a little more data.
  1. Have you always had issues creating drawings?  If not, do you only have the problem creating drawings from one design?
  2. Using a file browser, can you navigate to the directory %TEMP%\Neutron, right click on the directory "FusionFileOutput",  and select Send To > Compressed (zipped) folder.  It will create a file named "FusionFileOutput.zip".  Can you send that to me (kris.berg@autodesk.com)?
Thank you,
Kris Berg
Kris Berg
