Error running simulation: DEPENDENT DEGREE OF FREEDOM MAY ONLY BE SPECIFIED ONCE
When running a static force simulation I get the error as shown in the title. It states that a dependent degree of freedom was specified more than once. I have no idea what that is about. Maybe I did some errors in my setup.
This is my model:
https://a360.co/2vfc8Dk
It's a bunch of components linked together with rotational joints, and I fixed the bottom for the simulation.
It's supposed to stand on the floor.
henderh
Hi @Anonymous,
I suspect the reason for the error is that the anchor point is defined with a vertex, but the dependent entity(ies) have a face selected that includes the same vertex as the anchor point.  You can redefine the anchor point to a different vertex and the solve will complete without error.
You mentioned using joints, but Simulation is unaware of the joints defined in the Design / Model workspace to define the degrees of freedom of the mechanism.  Instead, you'll need to define contacts in the Simulation workspace to define the mechanism's DOFs.
Edit: I've logged an issue to detect the condition in pre-check as ID 49543.  Thank you for bringing this to our attention.
Hope this helps!
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Thanks.
I don't really know how to make my model behave correctly for the simulation, but that's off topic here 🙂
