Error: Rib cannot be created. Ensure profile curve can intersect body, or flip
I am trying to create a strut between a horizontal and vertical beam at 45 degrees. This is to increase stability for a steel frame and so I will want to have multiple struts to support the frame under loading so it can be safely stacked and moved around via a crane.
I have followed all the tutorials I could for the Rib feature which seems like the most direct way to create a strut, yet I can't seem to figure out what the issue is with my workflow.
I have linked a screencast to try and explain the problem further. I am new to Fusion 360 having come from SolidWorks so any help would be greatly appreciated.
It seems the screenshot was not attached, see link below:
https://knowledge.autodesk.com/community/screencast/4bd3d443-b0a4-4dc6-a260-f6ce3f6ccae9
HughesTooling
Rib only works on one body, your L shape is made from 2 bodies.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks! I knew it was something simple that I was missing.
