I just installed the demo to see if I can figure this out and I'm going through the tutorial and it is not following the actual software. The tutorial is the Modeling Basics: Basic modeling techniques available in Fusion 360.
When I get to step 23 and try and pick an Internal mirror for symmetry and then I select the top two quadrants and I get this error:
Error: Could not determine the symmetry from the selections. Continue selecting edges and vertices, master side followed by mirror side.
I can't really get past this because no symmetry is selected.
Solved by James.Youmatz. Go to Solution.
Hi @Anonymous,
Welcome to the Fusion 360 Community!
I went ahead and tried the tutorial on my computer and it seemed to be working just fine. I am curious to see if maybe there is an odd number of faces on the quadrant you are selecting which is causing Fusion 360 to be unable to determine its symmetry line. Do you think you could post a screenshot of the step you are on including your sculpt box and the symmetry dialog box? This would be really helpful.
Hi, I saved it to the cloud but when I restore the file, it takes a really long time and then there is nothing in the file/project. So I did repeat it and it seems to work now. So, yes, I must have done something incorrect.
