- Mute
- Permalink
- Report
I'm having quite a bit of trouble remixing an STL. I'm trying to modify the file to add some assembly registration, snap fittings and magnet inserts.
I have done the following up to this point:
1. Import STL and insert into design
2. Stop capturing history
3. Converted the Mesh to BREP
4. Started capturing history
5. Scaled the body to the desired size
6. Performed a split body on an arbitrary offset plane. I've found this gets rid of a lot of the unnecessary faces/vertices on converted solids
7. Recombined the split bodies
8. Created a sketch on a face of the resulting
9. Tried to use the sketches to extrude and cut the new body.
This results in the following error
Error: inconsistent information in vertex and coedge attributes
I've done this method with other more simple models and it has worked. I've also tried using the converted solid body as a cutting tool that intersects with another body.
Any help would be appreciated.
