Error in imported STEP file
Hi
 I have a issue regarding quality of imported STEP file to Fusion 360
 Check out & compare the below model. One is designed with SpaceClaim & other is STEP file imported to Fusion 360. Is this a Bug?
 I need a solution.
innovatenate
Autodesk Support
Autodesk Support
It looks like there is a problem in the translation process. You may want to run the Validate command.
If this doesn't help you may work around the issue try translating a different format like IGES or SAT. If possible, could you share with me a copy of the STEP file? You can e-mail it to nathan DOT chandler AT autodesk DOT com.
I hope this helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
