Error: Circular dependency found
patrik-web
patrik-web
I've started getting these errors in my design lately. Sometimes they happen when I update a linked component, sometimes they happen when I try to rearrange the timeline. When they happen, most components just disappear. What causes these errors and how can I track down what's responsible. "More Info" doesn't say anything beyond the same error message. Usually the error references something like "from <joint> to PositionX", but when I manage to find the joint it seems completely unrelated to the operation I attempted to do. It's quite frustrating to get these because there's no way to figure out what's wrong, so any tips would be helpful.
If anyone wants to take a look at the design, let me know and I'll send you a link.
/Patrik J.
jeff_strater
yes, please.  If you can send a link in a Private Message to me, or add me to your project (jeff.strater@autodesk.com), we will take a look at it
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
zhanganchun
Hi Patrik,
Thank you for your model. We have fixed the circular dependency issue in your model, and the fix will be included in next Fusion release. This issue is revealed by reordering in Timeline. So if you still have this issue, as a workaround currently, could you reorder the Timeline node "Component Insert Fuel injector boss ..." (near the warning sketch as the attached image shows) 10 steps before to see if that works? Thanks!
Terry
Software Engineer - Fusion 360
