Equivalent of an inset boolean in Fusion
Message 1 of 8
Hi folks,
I've recently started using Fusion for concept modelling, coming from Blender. One of the things that's relatively simple to achieve in the latter (at least with add-ons) is an 'inset boolean', as seen here:
What's the most efficient way of achieving this kind of result in Fusion?
Replies (7)
Message 2 of 8
g-andresen
try these
günther
Message 3 of 8
shahriarsifat1802164
Of course, you can make this stuff on Fusion.
Screencast: Prototype | Fusion 360 | Autodesk Knowledge Network
Thank you
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 4 of 8
RUET
Thank you.
Message 5 of 8
Hmm, it's not immediately clear what you've done here. How did you make the cut out on the curved surface? I see you've extruded something...?
Message 6 of 8
Ah, I've got it. Project the surface then I can do a two-sided extrusion to place the cut where I want it. Thanks folks!
Message 7 of 8
g-andresen
If you do not want the "extrude > offset"  variant, you can also create an offset plane (alternatively > midplane) for the sketch.
Sometimes this is clearer.
günther
Message 8 of 8
HughesTooling
Here's another option using split faces and press pull. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
