Entering back in the Sculpt Environment after you've selected "Finish Form"?
Hi, So I created a model in the sculpt environment and when I thought the model was what I wanted I selected "Finish Form" so that I was able to save it as an STL and then print it out on my Makerbot. It turns out that the model is not to the exact dimensions I wanted so I am trying to go back and edit the form. When I go to my saved file, I am unable to re-enter the "Sculpt Environment" to change my form. Is there any way to do this, or do you have to start completely from scratch?
Paul
JamieGilchrist
Hi pwhitaker1818,
welcome to Fusion.  I'm going under the assumption that you have modeled in parametric or capture history mode (this is the default mode).  If this is correct, then right click on the sculpt body in your timeline and select edit.  This will bring you back to the sculpt environment to further edit your sculpted body.
Hope this helps.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
