Enter a construction point using XYZ coordinates
Message 1 of 47
I am reverse engineering parts and need to enter construction points at XYZ coordinates.
Points only move to a relative position, there are no absolute dimension fields.
Dimensions to 0,0,0 wont work because the points are not on the same plane.
I need these construction points for manual measurements or when using CMM.
TM
Replies (46)
Message 41 of 47
jmpframce
I try your way but i get a message  that is not possible the csv file is mnot right
what could be the problem ?
thanks
PS :Fimport spline no valid point it is the message
jean michel
Message 42 of 47
TheCADWhisperer
@jmpframce wrote:
the csv file ...
Can you zip and Attach the file here?
Message 43 of 47
jmpframce
-19 -10 312
4 21 324
37 29 330
71 29 323
100 22 307
122 14 292
135 6 276
Message 44 of 47
TheCADWhisperer
File?
Message 45 of 47
jmpframce
Message 46 of 47
TheCADWhisperer
File?
Message 47 of 47
jmpframce
i have load your application in addins but how to activate i tip on and nothing is open
thanks
jean michel
