Enclosure mouvement
Enclosure mouvement
sam_batti
Enclosure mouvement
sam_batti
Hi team,
Can you tell me if it is normal that my mouvement is not easy with the mouse when I try to open and close the enclosure ?
the join is on the back and I try to open the enclosure from the front side.
thank you
CGBenner
@sam_batti
Can you explain what you mean by the movement being "not easy"?  It appeared to move smoothly in your video.
Can you share the design file here for others to test?
Chris Benner
sam_batti
here is the design.
I mean, that when I try to open the door, I must clic many times with the mouse on all direction to execute the rotation mouvement.
jhackney1972
To animate your model, Animate Joint Relationships on the Joint indicated in the video.  I think you have a break over center situation on your cylinder mount which is making it hard to animate completely closed.
(view in My Videos)
John Hackney, Retired
sam_batti
Thank you for help, ,I will use your recommandation. I will try to resolve my break over center.
