Hi there
Im trying to reanable "capture design history" after disabling it for a short time (needed to make a component independent).
Any idea how to get it back?
https://knowledge.autodesk.com/community/screencast/73a70573-51ed-49dd-91f1-c2354c7c3045
Hi there
Solved by innovatenate. Go to Solution.
Can I ask what you are trying to accomplish by re-enabling the timeline?
Once you disable the timeline, the parametric history is lost and converted to direct modeling data. Turning the timeline on again will reflect this. You'll note that the extrudes and other feature that comprise bodies are converted to a direct modeling feature called a "Base Feature" in the timeline.
Another thing that I note is that there a lot of warnings in the browser for the joints that exisit in this model.
If I go through your browser and generously remove assembly joints that have failures. I can get the timeline enabled, see the below link. I note there are still a lot of errors in the timeline. I tried to go through and delete even more joints, but I may have missed a few. At any rate, I think the joint failures are the root cause of the issue.
I note you may want to consider re-assembling to take advantage of XREF's and help keep the timeline simple and short.
If you right click on each component group in the model browser and then perform a Save Copy As, you can create individual designs from the component groups. I note that you may be have an easier time enabling the timeline in designs with less compoents.
Later, you can quickly reassemble by using XREF's. To do this right click on a design in the data panel and select the Insert into current design command.
I hope this helps!
I hope this helps!
There was a component i copied and assembled in my construction... later i needed to make some adjustments only to this component.
the only way i found was to make that component independent, so the other copy was not affected... so i needed to deactivate my history (i thought this would just "pause" the tracking of the history, not deleting it)...
is there another way to do this?
sorry if this is a stupid question 🙂
and another thing is, i dont know where the joint errors come from...
this think was nearly completly assembled, and now after i deactivated history BAM they are everywhere.
im getting better in using this nice program (only 12-20 crashes a day now... 2 weeks before it was like 60 crashes a day)
why is this tool so crash sensitive? XD
u cant tell me that learning a new programm involves 1000 of crashes?
From the other discussion for this design (below), I noticed that the timeline contained lots of warnings and errors.
Ideally, none of these would exist in the timeline. They usually indicate that a feature dependencies has been broken. Generally this happens when geometry is changed in a design and the downstream features are unable to resolve the reference geometry. At this point, you would need to edit the feature and re-associate the geometry or rebuild the features to remove the warning and errors.
The Modeling Best Practices blog post below, explains this in better detail.
http://www.autodesk.com/products/fusion-360/blog/fusion-360-modeling-best-practices/
The below free class about large assembly from last year's Autodesk University may also offer some tips to help manage the assembly and stay error free.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2015/fusion-360/cp10167#chapter=0
Because these errors existed in the Timeline before disabling "Capture Design History," the errors will also exist after in the "Direct Modeling" environment.
To create a component that is not "linked" to the original component:
One thing that is important to note is that the construction of your components do matter! This is why the best practices link above is very helpful to understand. Depending on how you build the components, some features may or may not move around with the components as you use one of the methods above to generate a new component.
