Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Embossing
1 REPLY 1
260 Views, 1 Reply
Embossing
I will be darned if I can find the emboss feature in fusion 360. Is it not a possiblity right now??
1 REPLY 1
Oceanconcepts
There is no emboss command as yet. Depending on what you want to accomplish you may be able to use the extrude and boolean operations to get there.  If you want to do text or logos there is the ability to import SVG vector files which can be used as a basis for creating solids.  This is a feature that we are told is being worked on- you can add kudos to ideas in the idea station to help promote them.  http://forums.autodesk.com/t5/Request-a-Feature-Fusion-360/Emboss-Soft-Select-amp-Painted-Displaceme...
- Ron
Mostly Mac- currently M1 MacBook Pro
