Message 1 of 11
Hello, I am a beginner fusion user.
I am trying to emboss a circular, brick like patten on a chamfer. When I try to emboss the pattern it curves more than it should. I've tried to change the angles and positioning to make it fit, but nothing makes it fit the inner circle
I've tried to experiment with simpler objects. I have a chamfer on a cylinder with a rectangle embossed on the chamfer. When I emboss it the rectangle curves instead of staying straight.
Is there any way to fix this. If not are the any alternatives to create the pattern I want.
