Ellipse dimensions in 2D drawing
wmhazzard
Advisor Advisor
Message 1 of 11
wmhazzard
I can't seem to be able to put dimensions on an ellipse in a 2D drawing of a 3D model. The dimension tool will not snap to the edges of an ellipse. Any way of doing this?
Replies (10)
Message 2 of 11
cmiller66
Hi wmhazzard,
You should be able to dimension the extents of the ellipse by using the Quadrant osnap override on the right-click menu, but is see other dimensions (like distance between foci and radii) are not possible.  You may need to manually dimension these values be either creating some sketch geometry in the design and turning it on in the drawing, or using the leader tool and entering values.  Not sure if that will satisfy your requirements, please let me know.
Chris
Message 3 of 11
wmhazzard
Chris, thanks for the reply, I used a leader and entered the dimensions manually.
Bill
Message 4 of 11
novakLT3XW
Hi Chris,
what can I do in case that part is not positioned parallel to axis system? My quadrant is away and I do not want to move all components...
Screenshot:
Thanks in advance for any information!
Tomas
Message 5 of 11
HughesTooling
@novakLT3XW  Think you'll need to create a sketch in the design workspace then make it viewable in the 2d drawing.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 11
bram_van_scharen
strange "solution", really wondering why it is not possible to put the dimension on an oval
hope this is one of the upcoming new features in the future!
Message 7 of 11
HughesTooling
This should work now using an aligned dimension and a midpoint snap. After selecting the aligned dimension tool, right click and select midpoint from the snap menu add the first point then repeat for the second.
Here you can see I've added the dimension using midpoints.
Mark Hughes
Message 8 of 11
colinNJB25
Wow, Thank you Mark! I didn't see this feature sneak in.
Message 9 of 11
etfrench
Does that actually work on an ellipse?
This was done with a quadrant snap:
ETFrench
Message 10 of 11
colinNJB25
It would be really nice to be able to select the foci of the ellipse. But I hvae been able to select the edges of the ellipse with the aligned dimension. Interestingly, it fails to give the correct values on a isometric projection.
Message 11 of 11
MaxMustMake
Community Visitor
Community Visitor
Thank you this was just what I needed. I am trying to dimension an oval bottle and was really getting frustrated. Linear dimension worked perfectly!
