editor
editor
magpiemachining
editor
magpiemachining
hello. i have fusion for mac and notepadd++ can not be used. can someone recommend a suitable alternative? what the techs at fusion are using is to edit post is preferred if anyone knows. thanx
innovatenate
Autodesk Support
Autodesk Support
I've been using TextWrangler. I'm very curious what other text editors may be used out there. Thanks for posting this question.
Nathan Chandler
Principal Specialist
magpiemachining
another tech at fusion recommended sublime. i found i was able to edit using the brackets. im still learning and working on this so im not sure if ill get the results im looking for. my "IT" guy is looking into this also. i have through spindle coolant and need to add this to the coolant list. right now there is no way for the post to know what the code for that is. it doesnt know what m63 m64 looks like. it knows what m9 m8 m7 looks like.  i hope im explaining this right.
