- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a STL file of a propulsion wheel for a tennis ball training machine. It converts a tennis ball machine to a pickleball machine. The design is for a different machine and for my machine it needs to be bigger. There is a center hole for a screw to secure the wheel which currently fits perfectly. I was able to make the wheel bigger, from the current 118.36mm to 138.36mm, but it changes the entire unit so it also changes the size of the hole in the center.
How do I make the outer diameter bigger without modifying the size of the hole in the center. I am guessing I need to split the single unit into parts but I am a beginner on 3D design and printing so need help on this.
