Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Editing sketch for base extrusion magically makes extrusion thinner ;-)
1 REPLY 1
TrippyLighting
230 Views, 1 Reply
I came across this odd behavior. A lot of errors for missing geomtry are displayed after paerforing a simple editing the skech of a base extrusion of a part.
It takes too many words to explain, so here is a screencast:
https://screencast.autodesk.com/main/details/73a4c953-22bf-4698-9a09-39c3098bba03
This may not be an error in F360 behavior but perhaps I've inadvertantly done something durnig the design process that causes this behavior. Looing for some clues.
Peter Doering
1 REPLY 1
I figured out what the problem was. This one is on me 😉
A somewhat questionable sketch prior in the timeline caused this behavior. Once corrected the part "behaved" correctly.
Peter Doering
