Editing shapes and fillets // design help
joel
joel
Hi!
I'm currently trying to design an automatic bartender which will be controlled by an Arduino. The whole body of the bartender will be 3D printed. I've come up with a design I'm fairly satisfied with, but after 3D printing a prototype, I've realized that the hole for where the glass will go is too small. Mainly it's the height that is the problem but would like it a bit wider as well.
There are 2 pictures attached of my design and the .F3Z file is also attached.
What would be the best way to enlarge the hole? I've tried doing surface offset but it only gives me errors.
The best would be if you could cut the hole where I've marked red lines in the picture: Bartender 1_li.
Thanks in advance
Joel
etfrench
Press/Pull seems to work, but you may need to remove all of the fillets first.
ETFrench
