Editing Parameters Outside of Fusion
jsmPGF5C
jsmPGF5C
Hi everyone.
I may be thinking beyond the capabilities of Fusion here, but I'm wondering if anyone has any ideas... So I'm creating a parametric model that is fully defined by a set of around 50 user parameters. I want to make some sort of interactive model so that clients can edit the parameters of the model and watch it change. Ideally I'd want the model in a viewer, where parameters could be changed, instead of in the Fusion workspace.
Anyone know if something like this is possible?
TrippyLighting
Here are two resources that might help you:
Fusion 360 sheeter plugin
Autodesk Project Play
jsmPGF5C
This is exactly what I need! Thank you. I had actually asked a similar question before about driving parameters from a spreadsheet... I was under the impression that the only way to do this was import/export CSV files. Sheeter is much more user friendly. As for Project Play I cant believe I’ve never seen it before it’s an amazing tool.
Thanks for your help
