Edit under a sketch
Edit under a sketch
Edit under a sketch
I'm trying to make fidget spinner caps that look like cat paws. I need to make the paws on the side you hold, and I can't figure out, or find online, how to edit underneath the sketch so I can continue to make the nubs for inside the bearings on the other side. Any help would be appreciated, thanks
venkitr
From the description looks like you would want to create sketch entities beneath the sketch where you have created the cat paw.
In that case you could create a workplane offset from that sketch and create a new sketch on the workplane.
Any additional information on what you attempt to create might help (like screen shot or the file).
Are  you attempting to create the Non Uniform Ball Spacing(NUBS) cage for the bearing ?
Rajesh.V
Fusion 360 Developer
Link Name | Link Name | Link Name | Link Name
