Edit sketch dimensions in Solidworks file
larsNR7Y2
larsNR7Y2
I got sent a file from a friend that I'm trying to edit but however I try to edit or create sketches I will over constrain and not be able to edit any dimensions, and since there is no timeline I'm kinda stumped on how to edit dimensions on an imported file from Solidworks. I've attached the file, ideas?
Thank you, Lars
TheCADWhisperer
I examined the file in SolidWorks.
Apparently whoever modeled this in SolidWorks does not know how to use a CAD program.
You can either use direct editing techniques or additional sketching as required.
Frankly, I would use this only as reference and recreate the part from scratch in Fusion using proper modeling techniques.  Should take less than 10 minutes of effort.  If you have trouble - File>Export and then Attach your *.f3d file here and I can show how to model the part.
g-andresen
here is a little help to go the way of @TheCADWhisperer
Step 1 > activate design history!
regards
günther
larsNR7Y2
Thanks to both of you, I'll redo the part and get it right the first time around.
