edit properties importing DXF files in Fusion
jean-michel_legoff
Message 1 of 12
jean-michel_legoff
For any reason it looks like enntities on layer "1" are displayed as "construction lines"...
Could it be possibel to edit this property?
if it's not possible to modify this behavior in the software which generate those DXF?
Many Thanks
Replies (11)
Message 2 of 12
johnsonshiue
Hi Jean-Michel,
I could be wrong but I don't think Fusion dictates the behavior. It seems that the layer 1 line type in the exporting drawing is set to construction line type. Or the template used to export the DXF is set as such. You may verify it by opening the dxf file in DWG TrueView or viewer.autodesk.com.
What system does the dxf file come from? Could you share it here? I might be able to take a look to understand the issue better.
Many thanks!
Software Test Engineer
Message 3 of 12
TheCADWhisperer
@jean-michel_legoff
I think I have an easy solution - but would need to see the actual file.
Message 4 of 12
jean-michel_legoff
here some files,
you may see that it's not depending of the originator (RCS, ZW CAd or Illustrator)...
as long as entities are on a layer called "1" Fusion attributes the type "Construction"...
It should be valuable to be able to modify this behavior, either in a "preference" or as an option in the import Dialog.
Message 5 of 12
TheCADWhisperer
@jean-michel_legoff wrote:
Could it be possible to edit this property?
@jean-michel_legoff
Select Edit Sketch
Window select, crossing window select or Ctrl select the construction geometry that you would like to change the property.
Right click and toggle Normal/Construction
Another alternative would be to P project into a new sketch.
I just tried with your files and works fine for me.
Message 6 of 12
jean-michel_legoff
yes I know that it is possible to edit this property, The issue is not there…
the issue is that this behavior is not expected and comes in Fusion I don’t know when… and found it a little enjoying to can’t revert to the original one.
Message 7 of 12
TheCADWhisperer
Do you have access to AutoCAD?
Message 8 of 12
jean-michel_legoff
Yes, may be, but I don't see what it will change...
I don't want to open the RCS DXF file in a Trd party software only to rename the "1" in anything else...
I need a pref in Fusion where I can name the "construction layer" to 1 or any aother name, or deactivate this "remaping" feature
Message 9 of 12
HughesTooling
@johnsonshiue wrote:
Hi Jean-Michel,
@johnsonshiue Although Fusion exports to Layer1 and sets the line type to construction, with imports everything on layer 1 comes in as construction lines. This has caused problems with some add ins that used layer 1.
Mark Hughes
Owner, Hughes Tooling
Message 10 of 12
TheCADWhisperer
I didn't fully understand the issue as a Layer induced issue.
I was going to suggest running the List (LI) command on the lines that convert to construction in AutoCAD to see what properties they had different than the other lines.
Message 11 of 12
jean-michel_legoff
there are no properties applied in the lines of the file.
for exemple in the "untitled-1_AI" file coming from Illustrator all the profiles have the same properties, only the circle is on a layer called "1"
Message 12 of 12
jean-michel_legoff
and in the opposite way
exporting a sketch from Fusion where the "circle" is set as "construction line"
in Illustrator it opens with all on the layer "0" and only the "circle" on Layer "1"
