Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Newbie lesson:
Created a cube by extruding a rectangle. Then solid/hole to create a thru-hole from one the cube's face. Learned that I can move the hole using the timeline to select the hole's features.
Then tried to access the hole's feature by selecting the hole on the cube's face. Drew a box around the hole, left-click, etc, could not select the hole itself -- except by rotating the cube and selecting the hole from the backside.
Learned: I was viewing the cube shaded, at an angle. To select the hole from the original face, I needed to draw a box that encompassed the entire hole as it passed through the cube, including all non-visible portions.
I get this, kind of.
K
