Edit file
Edit file
Edit file
I have a simple question. Is it able to edit a file in fusion 360, which was produced in another software?
I want to edit a file in fusion 360, but I can only upload it.
Thank you. 😉
PhilProcarioJr
We need more info, what kind of file is it?
Phil Procario Jr.
Owner, Laser & CNC Creations
HughesTooling
If you uploaded through a web browser right click the design in Fusions Data Panel and pick Create Fusion Design. If you uploaded using Fusion's data panel you should be able to just open and edit.
Mark
Mark Hughes
Owner, Hughes Tooling
It´s a stp-file, but i can convert it
HughesTooling
From the file menu have you tried New Design From File. Also you can only import surfaces it with ignore curves and meshes.
Mark
Mark Hughes
Well, I can't edit it. I want to edit a step file, but I cannot use "edit form" or any other MODIFY tools.
That's my problem. I tried it with your idea, but it didn't work.
