Edges Or Faces May Be Crossing After Apply Symmetry
kencondal
kencondal
Hi All,
I have a rather simple T-Spine Form that converts without error when I Finish Form. However, when I apply symmetry and then convert, I get the Edges or Faces May Be Crossing error. I have checked and re-checked the body and can't find what is happening or why symmetry causes this error. At first I thought that some vertices along the symmetry line might be misaligned so (before applying symmetry) I did a flatten to the symmetry plane and then reapplied symmetry. Same error.
I have attached the .f3d file and would appreciate it if someone could explain what I'm doing wrong.
Ken
PhilProcarioJr
@kencondal
Here is the problem face. if you split it the problem is fixed.
Normally I never use 3 sided faces, but if your finished with this form it should be ok in this case. Personally I would still make it a quad, but again it's ok for this.
Phil Procario Jr.
Owner, Laser & CNC Creations
colin.smith
Hi @kencondal
I found the same problem as @PhilProcarioJr.
Uncreasing the edges will allow the form to convert.
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
kencondal
Hi @colin.smith and @PhilProcarioJr,
Thank you both so much for your help! This is my first foray into the sculpting environment and it's not as easy as it looks!
I must admit I'm a bit baffled as to why the form converted fine until I added symmetry. That's what led me to look in all the wrong places for a fix. I understand that triangles should be avoided whenever possible but sometimes they solve nasty problems. The creasing was necessary to hold some straight edges and I've found that sometimes a crease causes edges to cross, so I always keep an eye on that.
Can you give me any pointers on how you both found the error so quickly? Maybe if I knew what to look for I'd be more proficient.
Thanks again,
Ken
PhilProcarioJr
@kencondal
If you just look at the surface of the bad face you can see it folds in on itself.
Phil Procario Jr.
