rendering mesh material
camstuff
camstuff
Hello, I was trying to render a steel mesh grill like you would find on a stereo speaker, but when I go to render the mesh I have applied to the surface it just turns solid?
Thank you for any help.
cam
PhilProcarioJr
@camstuff
Which material are you using and could you show us a screen cap?
Phil Procario Jr.
Owner, Laser & CNC Creations
camstuff
I was able to get the holes to show... not sure what I did wrong the first time but how to I get rid of the spiral look and make it like it was a flat sheet of mesh that was stamped?
PhilProcarioJr
@camstuff
You need to use Plane projection for the UV mapping.
Phil Procario Jr.
camstuff
Thank you for you time - very helpful !!!
PhilProcarioJr
@camstuff
Did this solve your problem?
Phil Procario Jr.
camstuff
its not perfect but it did help.
