Edge banding: workflow suggestions
tookemtoni
tookemtoni
We’re starting to use a lot more edge banding.
How can you communicate to the workshop where the edge banding goes?
Note:
The workshop uses an Edge Banding Machine that removes the EB thickness from the destination piece and then installs the edge banding…so I don’t have to take an account for the edge banding dimension or model it. I would most likely just change the appearance of the face to represent the edge banding.
wersy
To show where the edge banding goes, you must first design the furniture.
tookemtoni
TrippyLighting
We can probably give you recommendations based on our experience in manufacturing, approaching about 4 decades in my case. But that might not reflect your situation.
I think you need to strike a balance between what the folks on the shop floor that do the actual manufacturing work, and what is possible in Fusion 360. Have you talked to those folks ?
tookemtoni
Thanks @TrippyLighting, I making the switch to 100% Fusion so I am excited to see if there is a better way than how we do it today.
The hope of this post hear what other professionals using Fusion were doing to communicate with their shops about edge banding.
g-andresen
in the screencast I show 2 procedures
(view in My Videos)
günther
Warmingup1953
Certainly worth a look is a PAID add-in JoinerCAD. I have only trialed it so I am by no means an expert.
Short intro tutorial:
https://youtu.be/bH4orncED_Y?si=OQR-AZIGmPgl-c9T
I assume because you have a milling edgebander you are a larger Enterprise? That being the case you'll be needing an Automated approach to communication to the shop floor. At a company I work with on projects we use Microvellum. This  sits atop an Autocad Licence (Not Fusion 360 unfortunately!) and it generates labels that communicate on the shop floor:
