easy way
easy way
sevildi
Message 1 of 13
easy way
sevildi
Herhangi bir delik olmadan sağlam bir hale getirmek için, vücuttaki delikleri doldurmanın kolay bir yolu var mı?
 Belge indirme linki  http://a360.co/2izte6u
Replies (12)
Message 2 of 13
Beyondforce
Hi @sevildi,
We want to help you, but you will have to write in English. Unless someone understand you language!
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 13
etfrench
Google translate thinks you want to remove all of the holes in the component.  Here's a video that shows one way of doing it.
If you just want to remove the text, then just delete those sketch lines and curves before doing the extrusion.
ETFrench
Message 4 of 13
sevildi
is there an easy way to fill the holes in the body, in order to make it a solid one without any hole
 document download link http://a360.co/2izte6u
Message 5 of 13
sevildi
Thank you for the answer
Message 6 of 13
daniel_lyall
You select all faces inside the cut out and Hit delete
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 13
sevildi
Will I erase all the letters like this one by one? 🙂
Message 8 of 13
sevildi
The video you made is very good. Thanks again
Message 9 of 13
daniel_lyall
Sorry about that a bit fast I can redo it slower if you want.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 13
daniel_lyall
Ben right click hit translate to english or your native language
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 13
daniel_lyall
Here is another way to do it, I have gone slower this time, When I swing the view over and de select the bits that are blue I hold down ctrl to do it then hit delete.
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 13
sevildi
Thank you for this beautiful video
Message 13 of 13
daniel_lyall
I learnt something new my self when doing that vid.
Daniel Lyall
The Big Boss
Mach3 User
