- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to sketch a six-sided polyhedron that consists of a square face on the lefthand end, and a rectangular face on the righthand end. These two faces are parallel to each other. However, no other measurements can be assumed -- one of these two faces may end up offset relative to the other in one or two dimensions, so this is not anything as simple as a truncated pyramid.
Is there an easy way to do this in Fusion 360? Intuitively I want to sketch the square and the rectangle in a 3D space, and then connect them with lines. Is this possible? Other kinds of approaches (for example, defining portions of surfaces and extruding them) seem like they would get complicated.
