Hi All.
So I am having to cut up a model for 3D printing and have a question if there is an easier way of doing the following to make the pin and hole align perfectly.
1. Create hole on 1 piece; chamfer edge to make inserting pin easier
2. Create circle sketch on connecting piece; extrude; chamfer top edge
My issue is on the faces there is no way I have found to make sure they are aligned perfectly snap to center of circular face. I am simply eye-balling the hole feature and then the circle sketch on the connecting face. See attached screen captures.
Here is screenshot of what I have...this needs to be done many times as the model is larger than my UM 3 print bed so I need to break the model up and the assemble.
Any suggestions greatly appreciated.
Cheers!
Rick...
