Easier way to produce a hole and a pin in connect 2 objects
rickjohnston
rickjohnston
Hi All.
So I am having to cut up a model for 3D printing and have a question if there is an easier way of doing the following to make the pin and hole align perfectly.
1. Create hole on 1 piece; chamfer edge to make inserting pin easier
2. Create circle sketch on connecting piece; extrude; chamfer top edge
My issue is on the faces there is no way I have found to make sure they are aligned perfectly snap to center of circular face. I am simply eye-balling the hole feature and then the circle sketch on the connecting face. See attached screen captures.
Here is screenshot of what I have...this needs to be done many times as the model is larger than my UM 3 print bed so I need to break the model up and the assemble.
Any suggestions greatly appreciated.
Cheers!
Rick...
TheCADWhisperer
@rickjohnston wrote:
Hi All.
You should not have to eyeball the connections, you simply Project Geometry the position from one body to another.
Be sure to allow a bit of clearance between the mating features as 3D printing is not very precise.
(BTW - since you asked for suggestions on "easier way" - Autodesk Inventor Professional does this for you automatically.  🤔)
rickjohnston
Thanks @TheCADWhisperer !
I've never considered the 'project' command...I'll need to check this out and figure out how this works.
Yes I always make the hole 0.2mm - 0.25mm larger than whatever the pin shape looks like (e.g. dovetail, slot...) really depends on the material I am using to print.
Thanks again!
Rick...
etfrench
I usually just use one sketch to do this.  Draw concentric circles, one for the pin and one for the hole.  Extrude cut the hole and Extrude join the pin.
ETFrench
