DXF layers toggle
DXF layers toggle
DXF layers toggle
I was able to import a DXF file with multiple layers. A dialogue box appears and gives me the option to turn on/ off layers, this is great.
What I am looking for is the ability to return to this dialogue box and change the layer selections to work on a different manufacturing process for this new layer.
jhackney1972
You will not be able to return the the DXF import to select sketches on a different layer but you can choose to create a unique sketch for each layer during the original import.  If you do not need the sketch later, you can simply delete it.
John Hackney, Retired
Thank you very much. This will achieve what I am trying to do.
