Hi Scott,
What I noticed was that the parameter “sigma” icon disappeared from my tool bar when I opened my DXF file. Each layer in the DXF was a different sketch which I expected and wanted. When I tried to edit a sketch I noticed that the dimensions were not labeled which means that it is not possible to relate one dimension to another. I had wanted to be able to adjust the sketch using parameters and dimensions that related to each other This was unlike any of my previous files that were done completely in Fusion360 using parameters and labeled dimensions, thus prompting my question on just how .DXF files are handled.
Here is the kicker. The original source for the .DXF I was using was Fusion360.
I started out with a bitmap drawing of Ludlum’s Perpetual Datework which is part of a clockwork.The parts are escentually 2D being primarily 2D shapes in sheet metal. I brought the bit map onto the “canvas” and adjusted its scale. I opened a sketch and proceeded to trace over the bitmap. I traced several parts before I tried to extrude one. The various parts overlapped each other creating a lot of small closed loops. I could not get Fusion360 to select all the individual pieces for one part. The selection set got “lost” when I zoom in close enough to see and pick on some of the smaller pieces I needed to select. I realized that I should probably have created a separate individual sketch for each part. I figured what the heck I could just kick out a .DXF file and plug it in to my old Autocad 2005 program use Autocad to separate out the part lines and arcs to individual layers which then would come back in as individual sketches. I knew that eventually I wanted to bring in other .DXF files this way so why not figure out how to do it. The .DXF file opened in Autocad2005 did not have the bit map in it. I did not want or need it.
Why am I using Autocad 2005? Because that was the last version I owned when I quit my consulting work. It runs fine under Win7 so I still use it for home projects. It opened the Fusion360 file without complaint. Fusion 360 accepted the .DXF file that Autocad2005 worked on without complaint. Fusion360 created 10 separate sketches one for each layer it found in the .DXF file. The bit map was not in the .DXF file opened with Autocad2005.
I am using a MacBook Air. I am seeing some thing that make me wonder about video hardware problems. I do not know enough about how Fusion360 is suppose to work to be able to identify the source of what I am seeing. Some color related cues such when a sketch is fully constrained do not seem to work onsistantly.
Regards, Alan
