DXF file import results in weird lines?
Message 1 of 9
Hi Guys, relatively new to Fusion 360 and have imported a part from auto cad and it just does not look right - either in models or in rendering - the basic shape is there, but I am concerned about the lines and what effect they may have if I try to print this?
Are these anything to worry about?
Replies (8)
Message 2 of 9
davebYYPCU
By "print this" do you mean 3d print, or paper print - you can't print to paper from Fusion so figure you can,
Save as STL, and see if it is a graphic hitch, the STL preview will show you.
I presume there are small lines in the original file, but I would redraw in fusion for a simple shape like that one.
Might help...
Message 3 of 9
Sorry - I meant 3D print.
Message 4 of 9
PhilProcarioJr
@Anonymous
Can you share the .f3d file so we can look at it?
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 9
Sure - attached.
Message 6 of 9
PhilProcarioJr
@Anonymous
There is nothing wrong with your model. The lines are nothing more then a gfx glitch from the LOD settings in the viewport.
I have checked your model and it should print fine...one thing I would do first though is to combine all 3 of your bodies before exporting to a .stl.
I made a video to show how to control the LOD in the viewport and will post it as soon as it uploads.
Phil Procario Jr.
Message 7 of 9
Great - thanks again - and thanks in advance for the video!
Message 8 of 9
PhilProcarioJr
@Anonymous
Phil Procario Jr.
Message 9 of 9
Awesome - thank you so much for taking the time - all sorted!
