DXF Export: Splines not visible in CorelDraw
Hey,
I just exported a sketch as a DXF and wanted to open it in Corel draw to do layers for lasercuttung.
CorelDraw (latest Version 21.2.0.706) doesnt recognize the splines. Done some testing with sketches with only a single spline and Corel wont recognize either FitPoint or Control Splines but all lines and circles etc are displayed as usual.
Any ideas?
I found a workaround by importing the dxf into Adobe Illustrator where they display fine and export again as a DXF. This file opens without any problem in Corel but it´s a very inconvinient workflow.
g-andresen
try Spline to Polyline
günther
TrademarkCreative
Awesome! Thank you for this little plugin. LIFE SAVER!
Here's who we use it.
Our Solution
First make sure you have updated Corel, I updated my X8 version with these
https://www.coreldraw.com/en/support/updates/#cdgs-x8
Second, go download this Fusion plugin
https://apps.autodesk.com/FUSION/en/Detail/Index?id=4611814297957846949&appLang=en&os=Win64&autostar...
This will allow you to export DXF as polylines
Third, import your DXF
The polylines typically have a ton of nodes on them. Follow this step by step to reduce the nodes
https://www.coreldraw.com/en/pages/items/1600160.html
