Message 1 of 8
DWG Issues With ACAD LT 13
I need usable DWG files in ACAD LT in order to manipulate/export for custom 2D CAM processing.
If you export a DWG from Fusion and then open in ACAD LT 13 everything is in paper space. That's OK, I'll just select the objects and move them to model space. Wrong. Does not work. No active model space says ACAD LT 13. No problem, I'll just activate. wrong. Does not work either.
So why can't I use a DWG file from one Autodesk product in another?
I really hope I can at least pass some type of Fusion export file through Inventor to get a usable drawing or I will have many man hours of work that is trapped in an unusable system.
