- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When setting a joint to a given value it affects several other unconnected joints. This also happens when using the align command. Capturing positions does not seem to remedy the situation.
Note, these joints are all instances of the same component. They seem to adopt an obsolete default value from one the first versions of that component. This value was removed and updates were applied. Even with the old default value in place I would not expect this behavior. Note: This old value is not the "home" for the joint. Idk where it keeps coming from.
Even motion studies can't manage to get everything in line.
How do I line up my components without joining them to the floor (because they aren't meant to be joined there, but they should align with it when extended)?
@mickey.wakefieldany ideas?
