Drill Holes (Cylinder) Possible Method Inquiry ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
23rd September 2015.
Dear Autodesk Fusion 360 Community,
I'm extremely new to the Fusion 360 environment, and so I must apologise for my ignorance !
With what I have learnt to date, via the online Fusion 360 Training courses and extensive literature, I'm hoping that the following "Drill Holes (Cylinder) Method Inquiry is possible !
I have shared the 2 models online via the following links : http://a360.co/1Mo2VtN ,and http://a360.co/1KKFKeb ,as well as the attached image (Drill Hole (Cylinder) Possible Method Inquiry - 23rd September 2015.jpg), in order to hopefully assist with my inquiry !
(a) I initially created a simple "Bolt" using the sample supplied script called "Bolt", using its default values !
(c) I then sketched a rectangle 200mm x 15mm, and "Extruded" it Symmetrically by 100mm to obtain a 200mm x 200mm x 15mm Panel !
(c) I then sketched a circle with a diameter of 5.5mm, being the "Bolt Thread Diameter of 5mm + 0.5mm Clearance, moved it by 3.5, and then "Extruded" it by 16.5mm, being the "Overall Bolt Length of 20mm - the Bolt Head Length of approximately 3.5mm !
This is all good, and now for my "Drill Holes (Cylinder) Possible Method Inquiry" !
The process would now be as follows !
(i) After creating the simple "Bolt" and the corresponding "5.5mm x 16.5mm Long Extruded Cylinder" I would initially save this item as an independent object, in the "Data Panel", which I could then load anytime it was required !
(ii) With a "Panel" being present I would then insert the "Bolt", so that it penetrates the "Panel" surface, by an appropriate depth !
(iii) What I would like to accomplish is that when the "5.5mm x 16.5mm" Cylinder associated with the now saved "Bolt", that as I immediately make contact with any of the 2 "Panel" Surfaces, or 4 "Panel" Edges, that the "Cylinder" cuts or produces a corresponding "Drill Hole" in the "Panel", proportional to the amount of insertion ! i.e. 7.5mm in produces a "Drill Hole" of 5.5mm x 7.5mm depth, and so one, that can then be appropriately machined via the Fusion 360 built in CAM Module !
I hope that I have adequately described my desired "Drill Holes (Cylinder) Possible Method Inquiry" !
(1) Is this described "Drill Hole" Method using "Cylinders" possible ? Please Advise !
(2) Is there another totally different method of achieving the above described "Drill Hole" result ? Please Advise !
(3) Can a "Script and/or Add-In" be created that can produce the desired "Drill Holes", after all required "Bolts", have been positioned in to the "Panel", and if so can I be provided with a sample "Python" script ? Please Advise !
I'm extremely grateful for your time and patience !
With kindest regards.
GEM CNC Systems.
