dremel 3d autodesk Print Studio c0000005
I installed Dremel 3D20 and 3D40 Idea Builder,
Autodesk PrintStudio on Windows 7, 64bit. (downloaded from dremel.com)
There were no errors and install said it finished successfully.
When I try to open Autodesk Print Studio I get:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Print Studio.exe
Application Version: 1.6.0.0
Application Timestamp: 57224844
Fault Module Name: libUI.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 57224837
Exception Code: c0000005
Exception Offset: 00000000000ffe82
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: eb79
Additional Information 2: eb798d4255ef7b3bd080f634a2875dcc
Additional Information 3: 1629
Additional Information 4: 16291a256a55de65af1cdb5faf860bc2
Any help is appriciated...
Update:
Problem signature:
Locale ID: 1033
According to Microsoft Community post(s)...
To troubleshoot issues with apps which are crashing and receiving error code c0000005:
http://answers.microsoft.com/en-us/windows/forum/windows_8-performance/exception-code-c0000005-causing-app-crashes/2d1c56cf-1363-4bf4-947a-57f2682c4265?rtAction=1465219509257
Method 1: Download and run the New UI App troubleshooter and check.
http://download.microsoft.com/download/F/2/4/F24D0C03-4181-4E5B-A23B-5C3A6B5974E3/apps.diagcab
Unfortunatly the diagcab did not execute correctly (for me on the Win7 Pro) ... I am posting on MS forums to find a solution and get a report...
Method 2: You may follow steps from the article mentioned below and check if that works.  What to do if you have problems with an app
http://windows.microsoft.com/en-us/windows-8/what-troubleshoot-problems-app
Followed all steps, but, PrintStudio still quits...
I have installed the PrintStudio Mac package (same source) but it unexpectedly terminates... see post:
dremel 3d autodesk Print Studio quit unexpectedly - Mac
Odd... any other suggestions, i.e., a trouble shooter that works...
What can we do to fix this issue?
 PS, I apologize for replying to my own post, but when the post link was restored I was not given an opportunity to edit...
That link is dead to download the software, but if you replace (https:// 3dprinter .dremel.com/files/3D40/Autodesk_PrintStudio_v1.6.0_Win64.exe) with (https:// digilab .dremel.com/files/3D40/Autodesk_PrintStudio_v1.6.0_Win64.exe) it still seems to work.
