I want to create a set of drawings of an assembly - with sub assemblies and components. I have used an automatic template. The first level assembly is fine with the BOM and represents the view last saved in the design environment. My problem is with the sub assembly - if the sub assembly is not aligned in the design environment the drawing views are not aligned to x,y,z axis. See pdf sheet 5 onwards.
I could align one of the legs but the linkages will still be a problem down the line.
Many thanks in advance for any help.
Pete
