I have a curved sheet made with three sections of different radii. In the original sketch I drew construction lines between the arc centres and the blend points and set the angles between those construction lines.
How can I show those angles on a drawing?
Really I need to be able to put points at the arc blend points and then draw construction lines between them and the centres, so I can measure angles between those lines.
Alternatively (maybe better) it would be nce to dimension arc lengths between the blend points.
(PS. I have heaps of dimensions that need to be re-associated - that will be another post).
